o rings for service plate
I am changeing o rings on service plate on top of lift cover along with a change over to the newer type plate , there are 6 o rings on the old plate, on the newer type are the 6 rings but there is also a channel with a place at the end of it which looks like an o ring will fit , should i fit an o ring into this or just leave it , i have checked the manuel but it only showes the older one not the newer type , could someone confirm for me if there are only the 6 rings or 7 on the newer type plate . Thanking you in advance Gerry
