Are these the so-called 'cheese head' bolts?
Please confirm:
--A & B are bolts & the same?
--C, D & E are screws & the same?
Where can I get all these?
Many thanks,
Stefan sent me some beading:russelm wrote:I am looking for some of the beading for the Instrument panel.
I have seen some on ebay but, wondered if anybody ahd any good pics of it or dimensions as I ahev used this company in the past for such things and they are quite a bit cheaper: http://www.sealsdirect.co.uk/
.The panel thickness is a critical dimension, so U46 is the only real choice. The 10mm sides on this are a bit big, which might give a problem going round curves. Perhaps one could pair it down with a steady hand.Wee59dexta wrote:Bensdexta could you (or others) have a look at http://www.sealsdirect.co.uk/shopping.a ... entId=4#21 and pick what strip you think best matches your description.
