Trailer Tipping pipe
Posted: Mon Nov 30, 2009 1:32 pm
by RossM
I've just received a trailer tipping pipe from Agriline but unfortunatly it doesn't fit. The end which fits to the aux services plate is 90degs in the wrong orientation. Looking at the manual this is because the early plates had the jack tapping plug on top where as my super dexta has it on the front to the left of the pull knob.
I've rung agriline and they've told me to return it but they don't do one for the later dexta's so looks like i'll be looking for one off a scrap tractor.
Posted: Mon Nov 30, 2009 1:53 pm
by GERRY
hi RossM i had the same problem and overcome it by screwing a1/2 black iorn male to femal bend into the tapping , and then the pipe into this, mybe you have ruled this out or it doesnt suit your setup but its worth try, it work for me . GERRY
Hydraulic Trailer Pipe
Posted: Mon Nov 30, 2009 2:31 pm
by Bensdexta
This guy makes them and might make you a 'special', if you can get hold of him via ebay!
I expect he will advertise another in due course.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0481683412
All the best,
Posted: Mon Nov 30, 2009 2:38 pm
by RossM
Hi Ben, The one in that picture is what I need thanks. The one I have from Agriline screws into the top of the flow valve.
Posted: Mon Nov 30, 2009 3:46 pm
by Bensdexta
RossM wrote:Hi Ben, The one in that picture is what I need thanks. The one I have from Agriline screws into the top of the flow valve.
Ross, that is strange as the one I got from Agriline has a banjo that goes on the front of the valve like the ebay one. I did have to bend the pipe a bit, but fitted OK.
Al the best,
Posted: Mon Nov 30, 2009 4:42 pm
by RossM
Very strange as when i rang the gentleman at agriline he told me they only did the one pipe. I wonder if its pot luck which type you get! If I bolt mine on it points to the sky!
