Rear wheel diameter
Rear wheel diameter
My Dexta has 24" rear wheels but I see the manual refers to 28" wheels. Were export (New Zealand) machines fitted with 24" as standard?
Re: Rear wheel diameter
It's worth a search on here & the old site on wheels - there is a ton of info on wheels/tyres. May not answer your specific Q about export standard.pjjms wrote:My Dexta has 24" rear wheels but I see the manual refers to 28" wheels. Were export (New Zealand) machines fitted with 24" as standard?
All the best,
The Swanndri Guy
pjjms, I think you will find 28" rims with 10x28 4 ply on Dextas were standard. 24" rims with14.9-24 were optional, but its probably more common to find Super Dextas with the optional 24" rims than with 28" rims in New Zealand.
Cheers TSG.
Last edited by The Swanndri Guy on Thu Jan 07, 2010 12:24 am, edited 1 time in total.
Fordson PETROL Dexta
Fordson Super Dexta
Ford 3000
Ford 4000
Valtra/Valmet 900
Fordson Super Dexta
Ford 3000
Ford 4000
Valtra/Valmet 900
Jos Cuypers
The Standard rear tyre is 11 x 28.pjjms wrote:My Dexta has 24" rear wheels but I see the manual refers to 28" wheels. Were export (New Zealand) machines fitted with 24" as standard?
Optionally the following were possible :
10 x 28 , 12 x 28 and 13 x 24
The 13 needs 24 dia to keep enough clearance between mudguard and tyre when put at narrowest width (52")
Rgds
Jos
Jos
