List of questions about my dexta
Posted: Sat Feb 13, 2010 8:32 pm
Here is a list of some questions I have about tractoring and the dexta in particular. I am new to all this, but willing to learn. I have been through a hundred or so old posts, which answered some of my questions, but not all. Here are some in no special order.
1. When working the tractor (plowing snow at this point), when things get tough and the tractor starts to slow and struggle under the burden, how high a rev should I have? At low, gear 2 the engine sounds good at '14' I think, which is exactly half way on my dial. Beyond that it seems a bit high. Do I just 'go by ear'?
2. After heavy plowing, the injectors, I think (the three devices on top of the engine with the copper tubing linked to them) can be a bit sweaty with diesel. this unusual. It does not drip enough to pool much.
3. Diesel seems to leak in very small amounts from just about every connection involving fuel, more so in the winter. Is that usual? Again, never enough to make a pool, just sweat.
4. Is there a minimum warm up time I should have after starting, especially in the winter? I have a motor warmarer, so it starts great and I idle while I do an inspection for about 3 minutes or so.
5. Is there any harm to the hydraulics if I keep my plow raised for an extended amount of time?
6. Is it better to increase rev from the motor, prior to lifting my plow (or using the hydraulics for anything else)?
7. Sometimes when working the tractor I smell a whiff of fresh warm oil. Just for a second. No signs of leaking. Problem?
8. Should I close the fuel supply tap when the tractor is not in use?
9. Should I run the PTO periodically to keep it lubed up? Just now I have no use for it. Do I press in the clutch to use it?
10. I have a auxiliary service control knob I think on right side near knee. I have no use for it now, but should I pull it out to lube up the bits associated with it? Or to get oil flowing, would I first have to hook up a device (wood spliter etc) to allow for oil to pass though the system?
thats enough for now!
