Good morning.
I am trying to remove the top cover (under the seat) on my dexta.
I believe that the bush that hold on the top link rocker sensing thingy needs to come out to release something inside, is this correct?
If yes how do you get it out? Mine is seized solid, and wont come out even when doused with penetrating oil and heat.
Any tips appreciated!
Regards,
Mark
Top link sensing rocker bush
Jos Cuypers
Mark,
if you mean Bush E66-GF-9. This part holds the rocker on the Rear Axle.
This bush is very difficult to be removed : I can only recommend to cut the 2 sides off. Open the metal saw, bring the sawblade inside the hole and cut further in axis direction. This will make a split bush from it. Than the tension is off the bush and can be removed easier.
A new part is avialable at Sparex - partnumber S.66250
Rgds
Jos
Jos
