throttle to dash rod connection
I am trying to repair the throttle on my dexta , the handle has been welded to the rod comming up through the dash , there should be a screw to hold handle to this rod , there is also a slot in the handle which i take it is to slip on to rod , which must have a rised piece or is it a grove for a cotter pin
also would some one know what size and thread is the smalll screw, hope this makes sence
Gerry
Re: throttle to dash rod connection
just seen bensdexta post i think it has my answerGERRY wrote:I am trying to repair the throttle on my dexta , the handle has been welded to the rod comming up through the dash , there should be a screw to hold handle to this rod , there is also a slot in the handle which i take it is to slip on to rod , which must have a rised piece or is it a grove for a cotter pinalso would some one know what size and thread is the smalll screw, hope this makes sence
Gerry
Chug-A-Lug
I'm in the same situation, except the welder wasn't too good at welding and my throttle lever snapped off a few days ago. It looks as if the throttle rod has snapped at some point in the past and is now too short, hence welding the lever on. Can you buy replacement throttle rods? I can't find any listed anywhere...GERRY wrote:I am trying to repair the throttle on my dexta , the handle has been welded to the rod comming up through the dash
Thanks all, Sam
Suggest you try Malcolm Hipperson for a 2nd hand one. I just got a spring clip for the top of my rod from him (see my earlier thread on this),Chug-A-Lug wrote:Can you buy replacement throttle rods? I can't find any listed anywhere...
All the best,
Chug-A-Lug
Just google, or phone or email him:Chug-A-Lug wrote:Malcolm Hipperson? Who's he? How do I get hold of him? I'm new to all this...
Ph: 01366-324394 Fax: 01366-324409 Malcolmhipperson@aol.com
All the best,
Chug-A-Lug
