Piping from manifold to fual tap!
I have a complete new piping from the manufold to fual tap, this is include nuts. Do old one has the previous owner put away. Now I must bend the new one but what is the best way to it it and where is the piping fittend, can someone help for the good way mounting?
Dunggatherer
The best way to bend the tube would be with a tubebender.
But if you are careful you may get away with bending it with your hands around a wooden stick or so.
On the one side it is connected to the fuel primer,under the tank.
It runs underneath the tank then,to the right side.
Then with a few curves upwards to the manifold.
On the "home" page you see a tab "Dexta".
There you find a Parts list.
One of the drawings shows the fuel system,with that pipe.
Good luck.
Rob.
Good luck.
Rob.
