				Injector information
				Posted: Sat May 29, 2010 8:42 pm
				by russelm
				Hi all
I have been checking my injectors over ready to get them setup/tested and I have found that I have 2 different coded injector nozzles.
I have
2 off NH153A
1 off NH389
So....I am assuming this is not ideal!
				Posted: Sat May 29, 2010 9:25 pm
				by russelm
				Just to add, the pintles in the NH153A's are free, the one in the NH389 is certainly not!
				Posted: Sat May 29, 2010 10:30 pm
				by GERRY
				I posted about the same thing awhile back but was unable to find out if the injectors could be identifed by their numbers, there is adifference in the size of the injection holes as the super has smaller  holes  than the standered dexta ,  Gerry
				Posted: Sun May 30, 2010 7:54 am
				by Tubal Cain
				Checking my notes I have Dexta nozzle has 2 x 0.35 mm holes and the Super Dexta has 2 x  0.32 mm holes.  The opening pressure is given as 160 atmospheres.
I would take the injectors to your local injector/fuel pump specialist and have him fit new nozzles and adjust the atomising pressure.  It should cost you about £60.00, which in the long run would be cheaper than refurbishing your old nozzles!
Gerald
				Posted: Tue Jun 01, 2010 8:06 pm
				by russelm
				Thanks all
I have called my local diesel setup for prices for injector refurb (County Diesels at Syston) and they want £47.50 plus the Vodka And Tonic each!
Has anybody any experience of:
http://www.southerntractorspares.co.uk
As they offer an exchange service at 21 notes each which sounds excellent.
				Posted: Tue Jun 01, 2010 11:56 pm
				by Bensdexta
				I think they are OK.
Do a search on here as I think their injector refurb has been mentioned before. I have bought parts from them, inc a duff heater switch which I'm waiting for them to replace.
				Posted: Wed Jun 02, 2010 7:23 am
				by Tubal Cain
				I have bought spares from them in the past and was satisfied with their service.
£21.00 seems a reasonable price to recondition an injector.
Gerald
				Posted: Tue Jun 15, 2010 12:10 pm
				by russelm
				Refurbed injectors arrived today
Here is a little pic:
More nice shiney bits
				Posted: Tue Jun 15, 2010 6:24 pm
				by marcusgs
				Hi, Russel,
Were those from Southern Counties?
I am thinking of sending some there too.
Regards,
				Posted: Tue Jun 15, 2010 6:40 pm
				by russelm
				marcusgs wrote:Hi, Russel,
Regards,
Yes they were.
A nice job done, recommended by me (I checked the pop pressures and spray pattern on the tester at the heritage centre this afternoon).
New nozzles fitted, bodies cleaned and reset.
Gets my
				Posted: Fri Jul 09, 2010 11:44 am
				by EddieJ
				Just had our injectors serviced, cleaned and reset at a local diesel specialist. One inject required a new nozzle. It all cost £60 collected them yesterday after they had them for one day.
Rich
				Posted: Fri Jul 09, 2010 1:05 pm
				by Chris Ivin
				Hi Eddie,
Where did you get yours serviced, I'm local to Coventry and mine need servicing.
				Posted: Fri Jul 09, 2010 1:52 pm
				by EddieJ
				Chris Ivin wrote:Hi Eddie,
Hi Chris
We went to Keresley Garage Coventry. Its on the Tamworth Road on the Fillongley side of the Royal Court Hotel.
Details:
Keresley Garage
Tamworth Road
Coventry, CV7 8JG
Phone: 024 76332642
Pretty good service but we haven't refitted the injectors yet. He charges £15 for clean test & reset then £15 per nozzle if required so this may cost £90 if all three injectors are in a poor state but ours were functional.. A local garage saves the faffing with postage and helps the local economy.
On another note I got a full head gasket set for £28 inc VAT from Sutton & Sons near Nuneaton and it was off the shelf! They do a lot of tractor refurbs so check out the website:
http://www.fsuttonandson.co.uk/
				Posted: Fri Jul 09, 2010 2:17 pm
				by GERRY
				Hi folks i got anew set of injectors from peter  slater acouple of weeks ago these are new perkins injectors cost £88 plus postage to ireland £13-50. no messing around sending in old injectors or any thing ,stright buy, just drop them in and away you go . Gerry
				Posted: Sun Jul 11, 2010 4:30 pm
				by Chris Ivin
				Hi Chris
Details:
Keresley Garage
Tamworth Road
Coventry, CV7 8JG
Phone: 024 76332642
Thanks Eddie,
Much appreciated.
