Injector Bleed-Off Pipes
russelm
Post by russelm »
Hi all, yet another question.
As part of my re-build, the engine is being fully stripped including paint being removed and when doing this to the bleed off pipes, I found this:
So, the question is, whats the best approach, remove the fittings (they look to be soldered rather than brazed) and replace the pipe with copper brake pipe?
Also, here's a little pic of my cracked head (replacement sourced from Agriline)
Image[/img]
russelm
Post by russelm »
Well, they are definately soldered!
A minute or so with the blow torch resulted in a nicely detached fitting and standard copper brake pipe is the same outside diameter (internal is slightly smaller but I suspect that this wont be an issue).
Hello Russel,
You are right. It's soldered. You could solve it like you say, but the part is new to buy for the major these day's. About 25 to 30 euros. Don't know if theres one for the Dexta.
russelm
Post by russelm »
Thanks Henk
I managed to find them for the Fergie but not specificaly for the Dexta (I suspect they will fit).
Think I may well go the copper brake pipe route as thats effectively a 'free' fix for me.
Post by Jerry Coles »
Hi Russelm
You have found the problem and identified a 'fix' but what was the cause?
What is routed in that area? Wiring or something, that what you must find to prevent it happening again.
Post by Bensdexta »
russelm wrote:I managed to find them for the Fergie but not specificaly for the Dexta (I suspect they will fit).
That seems to be the only fuel pipe that Agriline don't advertise on their website.
Malcolm Hipperson may have a 2nd hand one. I got a rear leak off pipe from him.
All the best,
Tubal Cain
Site Expert Team
Site Expert Team
Post by Tubal Cain »
The damage to the pipe looks as if it was caused by corrosion. If it had been chafing on another pipe or wire then the pitting would be smooth and bright.
Using a slightly smaller bore replacement pipe shouldn't cause any problems, as the amount of leakoff should be minimal.
Gerald
russelm
Post by russelm »
Jerry Coles wrote:Hi Russelm
Hi Jerry
Pretty sure its corrosion as other areas of the pipe are also pitted (although under the removed paint).
So, brake pipe repair it is, I will post a picture of the finished item.
russelm
Post by russelm »
Ok, all sorted.
On to the next job!
pjjms
Post by pjjms »
Nice job,
Good to see a part being repaired back to new standard rather then being replaced. Becoming a lost art.
