block changed from 144 to 152 Problems?
Posted: Thu Jun 17, 2010 12:28 am
				hi all recently told that my 58 block has been changed to a 152 what sort of problems can i expect here.
Took motor into the shop a few weeks ago as not enough compression to start and generally really stuffed.
Was under the impression that it was originally fitted with the F3-144 so ordered kit etc
The shop then tells me the liners are all wrong and to small, after measuring appears that the block is of 152 caliber.
Couple of questions
Head is indirect injection is this correct for f3-152 ?
Crank is that the same?
and what else will be different?in other words is the only difference between 152 and 144 pistons and linners?
Obviously was running well for some time but would like to do properly.
Couple of questions
