water pump rebuild or new
Posted: Fri Jul 23, 2010 3:55 pm
how do you know when you should just pay up and buy a whole new water pump?
Its making some noise(more than the motor)
it leaks a little
but it still pumps like a...
thing is $30 to $120 i know a new pump would be shiny and easy but what do i look for in the old one to know that it is beyond repair?
is it that hard to pull down? the impeller seems fine can i just fit a standard bearing seal?
it leaks a little
