				Super Dexta Radiator
				Posted: Sun Aug 08, 2010 8:35 am
				by Johnjt
				I have a NP 1984 Super dexta and wondering if someone could tell me what is the diference between the radiator on a Super Dexta and an ordinary dexta and would the radiator from an ordinary Dexta fit into a Super Dexta
				Posted: Sun Aug 08, 2010 9:24 am
				by GERRY
				Hi johnjt, i take it you ment a 64 as this was the end of the dexta production, the dexta rad will fit superdexta but idont think the superdexta rad  will fit into the dexta cowl, as the dexta rad is a bit smaller, you are better if you can the right rad for the right make.Gerry
				Posted: Sun Aug 08, 2010 10:42 am
				by pottyperkins
				My superdexta was fitted with a standard dexta radiator, But i changed it for the correct one as it could overheat when working hard
