Evening All,
Does anyone know the size of the thread where the pipe from the oil pump threads into the base of the block on a 58 Dexta?
Regards,
Mark
Oil Pump to block pipe thread
Ok Fella, Here's what i did, . Go to your local MF Dealer, Chandlers at Holbeach. Two ways to go from here. you can get a new pick-up pipe with the sump filter attatched, and a new pump to block pipe, for a Perkins 3cyl, 135 engine.
Or you can get new nut's and furrel's to fit your old pipes, but you wil have to bend the pipes a little and you need to be carfull not to crack them.
I did it the first way, (after advice from Brian), Your MF Dealer is the easist way to go. i . Agriline may have parts but to be fair i don't rate their parts all that much.
Thats my Two-penny worth and someone else may have a different view, Jim.
Thanks for the advice. That is what I shall do!
Sometimes you know I think there is a conspiracy out there, between these people out there, who re-manufacture parts, not only to get us to buy them, but then when we get them home, either have to modify them, or go back and spend some more money to get them to fit!
Or perhaps it's just me!
Mark
