Oil Pump to block pipe thread
Posted: Tue Aug 17, 2010 6:45 pm
by marcusgs
Evening All,
Does anyone know the size of the thread where the pipe from the oil pump threads into the base of the block on a 58 Dexta?
Regards,
Mark
Posted: Tue Aug 17, 2010 9:09 pm
by Jan 59
Thread is 7/8"UNF i.e 7/8-14tpi.
Regards Jan
Posted: Wed Aug 18, 2010 7:11 pm
by marcusgs
Thankyou sir your a star.
Posted: Fri Aug 20, 2010 6:36 pm
by marcusgs
Can anyone help again!
I need to know the thread size of the thread on the oil pick-up pipe that picks oil up from the sump please?
Thanks,
Posted: Fri Aug 20, 2010 8:48 pm
by YorkshireDextaMan
Why do you need to know the thread size? Have you fitted a new oil pump, and cant get the old pipes to fit.
Let us know and we can may be help. Jim
Posted: Sat Aug 21, 2010 10:50 am
by marcusgs
Yes. I have indeed fitted a new oil pump and the threads are completely different. Can you offer any advise please?
Posted: Sat Aug 21, 2010 3:31 pm
Ok Fella, Here's what i did, . Go to your local MF Dealer, Chandlers at Holbeach. Two ways to go from here. you can get a new pick-up pipe with the sump filter attatched, and a new pump to block pipe, for a Perkins 3cyl, 135 engine.
Or you can get new nut's and furrel's to fit your old pipes, but you wil have to bend the pipes a little and you need to be carfull not to crack them.
I did it the first way, (after advice from Brian), Your MF Dealer is the easist way to go. i . Agriline may have parts but to be fair i don't rate their parts all that much.
Thats my Two-penny worth and someone else may have a different view, Jim.
Posted: Sat Aug 21, 2010 7:05 pm
That is exactly what you have to do! We have had that problem since the 1970's.
Posted: Sun Aug 22, 2010 9:05 pm
by marcusgs
Thanks for the advice. That is what I shall do!
Sometimes you know I think there is a conspiracy out there, between these people out there, who re-manufacture parts, not only to get us to buy them, but then when we get them home, either have to modify them, or go back and spend some more money to get them to fit! :wink:
Or perhaps it's just me! :?
