I'am looking for the torque values of the piston rods.
Wher can i found them?
I found the manual http://www.fordson-dexta.de/downloads/section3.pdf but i can't find the torques for the rods.
Torque Tightening piston rods
Dexta Jan
Sorry for my bad english i am dutch.
Fordson Dexta 1958
Fordson Dexta 1958
The torque values are lower for Cadmium plated because cadmium exhibits lower friction than steel. It takes less torque on the nut to achieve the same stretch (tension) on the bolt. Is basically the same as when you see different torque values for dry and lubricated threads.Dexta Jan wrote:What is the different between the cadmium and the unplated?
The bolts are the same i think.
Cadmium plating is done primarily as an anti corrosion coating.
Jack
