				Torque Tightening piston rods
				Posted: Tue Aug 17, 2010 8:00 pm
				by Dexta Jan
				I'am looking for the torque values of the piston rods.
Wher can i found them?
I found the manual
http://www.fordson-dexta.de/downloads/section3.pdf but i can't find the torques for the rods.
				Posted: Tue Aug 17, 2010 8:44 pm
				by Jan 59
				See page 22 Torque specs.
Big end cap nuts  : cadmium plated  6.9-7.6 Kgm.
                            Unplated (zwart) 8.9-9.6 Kgm.
Succes    Jan.
				Posted: Wed Aug 18, 2010 9:51 am
				by Dexta Jan
				What is the different between the cadmium and the unplated?
The bolts are the same i think.
				Posted: Wed Aug 18, 2010 2:01 pm
				by commander
				Dexta Jan wrote:What is the different between the cadmium and the unplated?
The torque values are lower for Cadmium plated because cadmium exhibits  lower friction than steel. It takes less torque on the nut to achieve the same stretch (tension) on the bolt. Is basically the same as when you see different torque values for dry and lubricated threads.
Cadmium plating is done primarily as an anti corrosion coating.
