				tires
				Posted: Thu Sep 02, 2010 12:32 am
				by naildriver
				Buying new tires tomorrow. I currently have 13.6x28 on 12 in rims. Should I keep that size or go back original?
				Posted: Thu Sep 02, 2010 3:18 am
				by Aussie Frank
13.6 x 28 is the new designation for the old tire size of 12 x 28. If you have 12 inch rims then the tire you have currently fitted is the right size. You could even go one size up on those rims. One of my E27Ns has the same size fitted and they are marked 13.6/12 x 28 because they were made at the time when the size standards changed.
Your tire shop may even have a chart that they can show you that cross references all the sizes and what rims they can be fitted to.
Regards, Frank.
				Posted: Thu Sep 02, 2010 3:20 am
				by Mark
				Nails,
That would be up to you and what you are doing the most of with your tractor. I have the originals on mine, they do just fine for me. I use my tractor to plough, disc, bush hog, rake hay, mow hay.
				Posted: Thu Sep 02, 2010 3:54 am
				by naildriver
				I was mistaken about the rim size, I will measure tomorrow. The tire said 12" rim but I recall that it is 11. will ck tomorrow
				Posted: Thu Sep 02, 2010 3:58 am
				by naildriver
				Is there any know advantage to bigger tires. Were not talking much. Does anyone know about how much bigger this is
				Posted: Thu Sep 02, 2010 11:14 am
				by Bensdexta
				naildriver wrote:I was mistaken about the rim size, I will measure tomorrow. The tire said 12" rim but I recall that it is 11. will ck tomorrow
Beware of rim sizes, there are different ways of measuring it. The moden way is the internal bead width. Suggest you search on here for tyres/rims/wheels, there are lots of threads on the subject
