Tax disk holder...
Chug-A-Lug
Tax disk holder...
Post by Chug-A-Lug »
Just a small question. I bought a tax disk holder off agriline and assumed from the photo that it would fit either under the light switch or heater button... but it doesn't. The pre-drilled mounting holes dont seem to line up with anything.
I know it's probably a universal "one size (nearly) fits all" type product but wondered if anyone here had worked out where to mount it...?
YorkshireDextaMan
Post by YorkshireDextaMan »
It's very much like the original one's we used to fit to Dexta's. We mounted them on the top stud of the plate (on the timing cover) where you check the pump timing. Jim.
The other place is on the rear side bonnet bolt.
Nevis
Post by Nevis »
I also mounted mine on the bolt that holds the flywheel timing inspection cover. This also meets the legal requirements to be on the nearside of the vehicle
Chug-A-Lug
Thanks all. It's mounted on the pump timing cover. Reg plate fitted too :)
