I believe there should be only 6 stud holes and the four weight holes should be square.
Also there are 16" dia wheels and 19" wheels, which tend to be on earlier Dextas
Bensdexta wrote:I believe there should be only 6 stud holes and the four weight holes should be square.
Thanks for that, ours are 16 inch wheels and have 12 holes around the bit where the studs fit through, six for the studs and 6 spare ones for something or other. The weight holes are also round.
I ask because I have just bought two new ones and they only have six stud holes and the holes for the weights are square so maybe they are the correct ones for the job.
It could be that the Dexta had some odd wheels fitted as it had been used for some sort of fishing operation by the sea.
landowner wrote:Thanks for that, ours are 16 inch wheels and have 12 holes around the bit where the studs fit through, six for the studs and 6 spare ones for something or other. The weight holes are also round.
thanks again
Where did you buy your wheels? You did well to find them. Alot of the ones offered for sale have the extra holes. They fit but aren't correct
Got them from Tractorshack in Hanley , went for a ride out and had a look at the shop. He said there were three different types which will all fit the Dexta.
Nice guy who refurbs tractors as well.
01782 28 44 22 and he's open Saturday morning (ring first)
