				How many  holes in front wheels  (Super Dexta)
				Posted: Fri Sep 17, 2010 8:15 pm
				by landowner
				Help......
How many holes should there be in the front wheels of our 1964 Super Dexta and what shape should the holes for the wheel weights be please?
Some have round holes for the wheel weights and some have square.
Some have just six stud holes and some have a hole in between each stud as well.
Got to get it right,  people will only pick at it if it's wrong eh.
				Posted: Fri Sep 17, 2010 10:51 pm
				by Bensdexta
				I believe there should be only 6 stud holes and the four weight holes should be square.
Also there are 16" dia wheels and 19" wheels, which tend to be on earlier Dextas
				Posted: Fri Sep 17, 2010 11:41 pm
				by landowner
				Bensdexta wrote:I believe there should be only 6 stud holes and the four weight holes should be square.
Thanks for that, ours are 16 inch wheels and have 12 holes around the bit where the studs fit through, six for the studs and 6 spare ones for something or other. The weight holes are also round.
I ask because I have just bought two new ones and they only have six stud  holes and the holes for the weights are square so maybe they are the correct ones for the job.
It could be that the Dexta had some odd wheels fitted as it had been used for some sort of fishing operation by the sea.
thanks again
				Posted: Sat Sep 18, 2010 12:20 pm
				by Bensdexta
				landowner wrote:Thanks for that, ours are 16 inch wheels and have 12 holes around the bit where the studs fit through, six for the studs and 6 spare ones for something or other. The weight holes are also round.
thanks again
Where did you buy your wheels? You did well to find them. Alot of the ones offered for sale have the extra holes. They fit but aren't correct
				Posted: Sun Sep 19, 2010 9:12 am
				by landowner
				Got them from Tractorshack in Hanley ,  went for a ride out and had a look at the shop. He said there were three different types which will all fit the Dexta.
Nice guy who refurbs tractors as well.
01782 28 44 22   and he's open Saturday morning  (ring first)
Could have spent all day lookin rouind his shop
