I will post pics as soon as I can. I got too good of a deal on it to say no to a running tractor of any kind! If it weren't for this site I wouldn't have a clue as to what it was, much less the wealth of technical info I have already used to begin work on it. Thanks!
1962 Dexta
1962 Dexta
Hi all, I have just got a 1962 Dexta that I am trying to fix up after many years of use. It runs great but the steering is sloppy, water pump leaks at bearing weep hole, brakes need tweaking & the lift arms always seem to be slowly dropping. The motor runs tight and clean. Both clutches seem to still have life left. I believe it has spent most of its life mowing & baling Hay.
http://picasaweb.google.com/lh/photo/EM ... directlink
http://picasaweb.google.com/lh/photo/6_ ... directlink
http://picasaweb.google.com/lh/photo/-W ... directlink
http://picasaweb.google.com/lh/photo/w_ ... directlink
http://picasaweb.google.com/lh/photo/1h ... directlink
These are the pics.
A pneumatic governor you say? how would I be able to tell?
Anyone got a ballpark for a water pump price?[/url]
These are the pics.
Looks like a vacuum governor but she is a nice little tractor. Serial number will be on the flange between engine and clutch, behind the fuel pump. This will give more information on date.
Word of advice, the front wheels have been fitted the wrong way round. This will put a strain on the axle and steering. To avoid problems turn them back. They will run close to the king pin but that is OK.
Taggart,
Nice, clean looking tractor complete with headlights and grill screens. Did it come that way or have you replaced them?
I have seen several USA Dextas with the same grill guard bolted to the front axle.
Anyone know the make or what they were originally for?
Water pumps run around $100 on eBay (6 offered right now). Haven't priced them anywhere else.
Repair kits are also available, atleast in the UK.
Les
Les
Brian, Thanks! I thought that was the case just by looking at them but I wasn't sure. I'll flip them ASAP.
Lesfen, This is how I got the tractor. The only thing I have done to it is adjust the brakes, check clutch linkage and top off coolant.
I haven't decided as to return to factory condition or just work it's ass off. But it does seem to have a level of collectability so she might get cleaned up. It runs like a champ but the only thing I have issue with is the lift arms seem to have a leak down. It has Up, Down and Slowly creeping down. Sometimes I can find a sweet spot and get it to stay still for a short time before it continues to drop. Makes it a pain to bush hog when your blades start beating earth.....
The grill guard seems to be a standard ford one. I have seen a few on other ford tractors and all seem the exact same. I guess a dealer option. If I see any numbers on it I'll post.
On the side of the rear axle/lift, just under the main control lever is a little lever. This selects Draft (ploughing) and Position Control ( Bush hog, sprayer etc.), If it is pointing down it will be Draft if pointing forwards it will be Position. This could be what is wrong with your lift. Operator Failure
Thanks Brian,
But I had already read up on that control lever before I made posts. The lift arm still slowly drops even though the lever is up in the position control mode. I can get them to stop dropping by finding a sweet spot and then it will hold for a few minutes before resuming drop.
My life is never so easy as to just have a lever in wrong spot. I'm sure it will require a bit of disassembly to sort it out properly.
OK that is good to know! Not Operator Failure.
Try the lever in the lower (Draft) position, then move the main control lever towards the top of the quadrant. About 1/2" from the top stop the lift arm should start to rise.
If they do not, push the selector lever backwards.
If the lift starts to rise this would confirm that your Position control follower pin is worn or broken.
When you select Position Control with the main lever at the bottom of its quadrant, you should be able to move it slowly up the quadrant and the lift arms should follow it, stopping when you stop moving the lever.
Even if you have an oil leak, the lift should keep "bouncing" as the lift tries to automatically correct the dropping.
Sounds like you are going to have to take the lift off to sort your problem.
