Live clutch
Live clutch
The Dexta I just got is supposed to have the double clutch but..
it works the same in either yoke position (as a single clutch).
It is harder to push down than other Dextas so I am wondering if it was not aligned correctly and is it possible that both clutches are being separated at the same time?
Any others experienced the same?
Thanks,
Les
Thanks,
Les
Does the PTO stop in the forward position?
It is possible that the rod has been adjusted too tight. I would slacken back the rod first of all until you can just get the transsmision into gear without grating, in the first hole, then move to the second hole and see if the PTO stops.
The usual problem is a stuck PTO plate. Mine sticks after standing around but putting it on the topper soon clears it.
Brian,
Yes, the PTO stops in the forward position and it takes a bit of a heavy foot to push it down.
And it feels the same in the 2nd position, just have to lift my foot higher!
I have adjusted the rod as per the manual.
I have not worked anything on the PTO yet but will put the brush cutter on and head to a willow patch!
Thanks for the tip.
Les
Thanks for the tip.
Les
Re: Live clutch
I seem to have the same problem as Les, My PTO stops first when the clutch is depressed halfway, then the drive stops last. This is a pain when using the hyd. as i have to keep putting the gearbox in neutral to use the hyd. When im not moving, also the pto stops when changing gear.
Any ideas anyone?
Adam
Any ideas anyone?
Adam
Re: Live clutch
The clutch fingers are at two different heights and there should be no way they can be mixed. There is 3/4" between the transmission fingers and the PTO fingers so that the transmission fingers contact the thrust bearing first.
If the PTO plate was badly worn then the fingers would come close to the transmission fingers in height, if then, the adjusters on the transmission fingers were worn away the thrust bearing might contact the PTO fingers first.
Wear in the linkage on the transmission fingers could be another cause.
Do not think there is any way that the thrust bearing contacts on the fingers can be adjusted to such a point that the PTO contacts first.
Another point, clutch free play is obtained by adjusting the pedal stop on the clutch shaft not by altering the clevis as on a single clutch.
Re: Live clutch
I have had a good look at the clevis linkage on the bell housing since my last post. And there is only one hole in the linkage. So i guess my dexta is not live drive. Would this be correct?
Adam
Adam
Re: Live clutch
Yes, unless someone has swapped out the clutch rod. What makes you think she might be live drive?Burgman wrote:Hi
Re: Live clutch
When i push the clutch in with my airblast sprayer on, it stops the drive to the pto but it doesnt continue to drive the tractor on when its winding down. It seem to take the drive out between the pto and the gearbox also. Is there any other way of telling other than the clevis?
The Swanndri Guy
Re: Live clutch
Hi Adam, where in New Zealand are you and could you post some pictures of your Dexta/Super Dexta? TSG.
Fordson PETROL Dexta
Fordson Super Dexta
Ford 3000
Ford 4000
Valtra/Valmet 900
Fordson Super Dexta
Ford 3000
Ford 4000
Valtra/Valmet 900
Re: Live clutch
Hi TSG
I am in Putaruru in the south waikato. yea i will post some pics this weekend.
