Shocked by the state of my brake shoes
Posted: Sun Oct 03, 2010 10:26 pm
by Nevis
Last year I renewed the RH axle seal as it had been leaking and also therefore I replaced the brake shoes.
Recently I had noticed that the RH brake was not very effective so this morning I adjusted it and went for a drive. It still didn't work well so I finally decided to remove the drum and have a look.
Imagine my surprise when I discovered the reason for the poor braking - the linings on both shoes had partially broken away and disintegrated!
Any one else had this happen?
Andy
Posted: Wed Oct 06, 2010 4:55 am
by Taggart
Well this makes me feel like pulling my wheels tomorrow, I adjusted them the other day and they still just aren't what I'd like.
If I find anything similar I'll post, but I hope they look better than yours! :
Posted: Wed Oct 06, 2010 10:40 am
by Bensdexta
Those shoes must have been faulty to wear that quickly
Posted: Thu Oct 07, 2010 8:13 am
by Tubal Cain
It isn't wear that has caused the linings to break up. Either the linings were not fitted to the shoes properly or the material was incorrect.
I suggest that you replace them with bonded linings.
Gerald
Posted: Thu Oct 07, 2010 9:23 pm
by EddieJ
the rivets are the weak spot in the photos, maybe the friction material was not the correct circumference and the riviting caused cracks. Although I remember cracking the friction material off one of my car shoes being to heavy handed when putting the drum back and the shoes not being fully retracted.
Get them replaced by bonding
Posted: Fri Oct 08, 2010 9:18 am
by Nevis
Having the brake material bonded on seems a good idea as it would ensure that there are no stress points.
Can anyone suggest where I might get shoes with bonded linings or get replacement linings bonded on?
Posted: Fri Oct 08, 2010 8:43 pm
by Nevis
This morning I changed the brake shoes being careful to ensure that the shoes were central to the drum. However after only a few hundred yards the lining of the top shoe broke away again.
I checked that everying was assembled as it should be. The only thing I noticed that could be a contributer was that there is a lot of play where the brake camshaft rod passes through the back plate - the rod can move up and down about 10mm. I am surmising that this allows the brake shoes to rotate forward pinching the upper brake shoe. I checked the rod freeplay on the other wheel and it is much less.
What do others think?
Andy
Posted: Fri Oct 08, 2010 8:58 pm
by pjjms
If you take a brake shoe off and sit it inside the drum is the radius of both the same?
Posted: Sun Oct 10, 2010 12:18 am
by Nevis
I checked and the shoe and brake drum match closely
Posted: Sun Oct 10, 2010 7:06 am
by The Swanndri Guy
Nevis, is the brake drum round or has it gone oval?Also if the problem persists, swap drums to opposite sides, to see if that makes a difference.TSG.
Posted: Sun Oct 10, 2010 7:51 am
by pjjms
Andy,
When you replaced the shoes a few days ago did you replace the shoes with new, rivet new linings on, or have them relind professionaly?
Peter
