New member, some guestions and small part wanted ;)
Posted: Wed Oct 13, 2010 12:19 am
Hello,
I'm now for the first time in my life the owner of a tractor, a 1964 Fordson Super Dexta.
This is a whole new world for me, and I learn something new every day.
The tractor are not the most pretty looking tractor in the world, but to my surprise, EVERYTHING but one thing seems perfect! All the light, all the levers, brakes, wiring, pre heater, gauges, it all functions like new.
But one thing could be a bit better. The hydraulic for the front loader. It's strong as a bear, but it is SLOW! About 20 sec from the ground to max rised. And there seems to be delay before it kicks in when it has been on the ground for some time.
The rear hydraulic seems to be much faster and functions perfect.
I have tightened the flow control all inn, and that made it some what faster, but not as fast as i think it should be.
Any thoughts about what could be wrong and a possible fix?
Over to the engine and diff/gear/hydraulic oil.
Some tell me to leave it alone, and don't change it on these old engine/tractors, as that could make problems where there are non.
Any truth to that?
If not, what oil in modern terms should I use for the engine and diff?
And my last question/request:
The feed line for the diesel, where it connects to the diesel pump has worn threads, but I would like to avoid to buy the whole assembly, when I only need the top part.
Are there anyone out there that has this laying around that could take off the top part and sell it to me? I will pay for the part and all the shipping charges
Heres a picture of the pump, with the part I need circled:
Thank you so much for reading my thread
Any truth to that?
