Anyone set the governor on a Petrol Dexta or have the information on howto?
Have set this one to FE35 and TEA20 specs but doesn't seem to work. (They have 26 coil governor springs but this has 21.)
The low idle is too high (1150rpm) and after working on the brush cutter for a couple of hours then it wants to idle at (1565rpm).
(Used the pto speed X 3.333 to get engine rpm)
Thanks,
Les
