						Post
								by Bensdexta »
			How do I get this apart?
It looks like part 50, Spring, Valve Locking, is the key, but how?
TIA
						- Grumpy
						Post
								by Brian »
			Look down the pipe end, there is a spring clip to take out. Some types then screw apart with a screwdriver down the tube.
						Post
								by Bensdexta »
			Brian wrote:Look down the pipe end, there is a spring clip to take out. Some types then screw apart with a screwdriver down the tube.
Will I get it back together again? Any specal tools req'd?
Thanks,
						- Grumpy
						Post
								by Brian »
			Not on the ones I have done, these were either Dowty or Exactor. They did become a "throw away" item in later years.
