Can anyone tell me what would be causing the SIMMS injector pump (Pneumatic) to leak fuel out the bottom of the pump weep hole?  Its more than a few drops and seems worse when it is idling.  I have had the pump rebuilt, and have replaced the small pick-up pump.
Any help would be great...
Orange Wheels Are Cool..
									SIMMS Injector Pump Leaking
58 Orange Wheel
						Brian,Brian wrote:Have you got a curly pipe fitted or just a straight one?
I have replaced the lift pump, have added the curly drain line, and had the injector pump checked again. It still leaks an excess amount of fuel especially when idling.
I am not sure what to try next, maybe add a catch can to recycle the fuel.
Love orange wheels.
58 Orange Wheel
						There are only two places that diesel can leak from into the pump. Lift pump and pumping elements, so its got to be one or the other. Your pump repairer should be able to check this out for you on the test rig.
