I have roughly wired up the new headlamps on my super dexta and have a question about the ignition wiring.
From memory, there are four terminals on the ignition barrel, numbered 1 2 3 4. Currently, the new lights are able to opperate without the key turned. Does anybody know which terminal to take the power from so that the lights only work with the key turned?
All lights operate without the ignition turned on most tractors. You cannot take the light current through the ignition side of the switch without burning the switch out.
If you want to modify the system, you need to fit a relay to carry the headlight current, which is operated by the ignition side of the switch, like modern cars.
