jerry wrote:Would like to replace the broken proof meter and cable on my 63 super dexta (diesel) Have only found 1 supply house in the US that lists this item the numbers that they list are OEM # cable 95717365C,75961 Proof meter OEM # 957E17360A,66929 can not find any part numbers in the parts list down load can anyone verify the numbers as the correct parts.
The online vugot.com (New Holland) parts list for Super D gives:
957E17365C  	 CABLE  	 Cable Assy., Years: 01/01/1957-04/30/1962
957E17365D  	 CABLE  	 Cable Assy., NH-E, A.C.Type, Years: 04/01/1962-12/31/1964
957E17360A  	   	 Tachometer Assy., Miles, Years: 01/01/1957-08/31/1960
957E17360B  	   	 Tachometer Assy., Kilos, NH-E, Years: 01/01/1957-08/31/1960
957E17360D  	 TACHOMETER  	 Tachometer Assy., Miles, Years: 08/01/1960-12/31/1964
957E17360F  	   	 Tachometer Assy., Sweden, No Longer Serviced, Years: 08/01/1960-12/31/1964
I don't know what the difference in the tachos is. Maybe the gear ratios changed in 1960
 According to my rather inaccurate Dexta book, the proofmeter did indeed change in 1960. See:
http://www.fordsontractorpages.nl/ubb/F ... 00103.html and
http://dexta.20m.com/photo4.html
And maybe the cables changed when the mechanical fuel pump arrived in 1962. Since you have a '63, I'm guessing you need the 'D' versions?? I believe the later cable is longer, so suggest you check the length.
I should put the problem to your supplier - he should know what he's selling for what!
Perhaps one of the gurus can enlighted us further?
Post Script:
I just serched the old site, see sticky top of here, and some folk say an MF 35/135 tacho may work (Bare-Co, calif)
Also try to fix your old tacho, nothing to loose
