bolts for gear sticks
Posted: Sun Jan 23, 2011 5:35 pm
by GERRY
would any one know which is the right thread and length of bolt for the gear shifter plate,
thanks in advance , Gerry
Re: Gear lever housing bolts
Posted: Sun Jan 23, 2011 7:23 pm
by Bensdexta
GERRY wrote:would any one know which is the right thread and length of bolt for the gear shifter plate,
Parts List says bolts are 5/16" 18tpi (ie UNC) with 7/8" hex head. Can't help with the length though
Re: bolts for gear sticks
Posted: Sun Jan 23, 2011 9:11 pm
by GERRY
Thanks Ben just what i needed , ican get the length sorted ok, it was the thread i needed ,i have a mixture of unc /unf
in mine and diddnt know which type was correct . Regards Gerry
Posted: Sun Jan 23, 2011 11:26 pm
by Lesfen
7/8" might be the length. They take a 1/2" wrench.
Les
Posted: Sun Jan 23, 2011 11:30 pm
by Bensdexta
Lesfen wrote:7/8" might be the length. They take a 1/2" wrench.
I think Les might be right - 7/8" head would be rather large!
Posted: Mon Jan 24, 2011 1:01 pm
by Tubal Cain
As a general rule you will find that bolts which screw into castings on the Dextas are UNC, whilst studs are UNC at one end and UNF at the other. In other words tapped holes in casting are invariably UNC.
As many of the tapped holes in the castings are "blind" it is essential that the correct length of bolt or stud is used. If they are too long it is possible that the casting will be damaged and in the case of the axle and gearbox castings will result in oil leaking past the threads.
Gerald
