Hi there. Just wondering where i can get the fuel tap and primer thing that goes under the fuel tank? The one on my dexta, has a catastrophic leak from where the fuel line goes in and up to the manifold, also the fuel tap bit is broken off, and the primer bit seems to be seized, so all in all not good!
Also what is the original set up on a standard diesel dexta?
Dexta fuel primer tap
Re: Dexta fuel primer tap
Hi. These are available here:
http://www.silverfoxtractorspares.com/f ... 1130-p.asp
http://www.smltractorparts.co.uk/product.php?id=6751
http://www.agrilineproducts.com/partsca ... dexta.html
If you get one, could you possibly send me your old broken one please?
I will PM you my address if you would be so kind.
Many thanks, Mark
Many thanks, Mark
Mark
Hi Mark,marcusgs wrote:If you get one, could you possibly send me your old broken one please?
Do you repair them?
Well, not really, I just have one knackered one and was going to try and make one good one out of two or three knackered ones!
Mark
If I was to change this pump/fuel tap out one more time, I would have searched for a OEM one, if thats posible to find.
I have now gone trough 3 of these aftermarked pumps in two months and they all had one thing in common,
they leaked where the primer pump connects to the fuel tap part. In two days the worst one would leak down 2 gallons of diesel.
The last one I put in had the same leak, but it seems to have gotten better as some "dirt" have made it trough the system.
Tom T. Winchester
Little did I know that all those days passing was life itself!
