A couple questions
A couple questions
I have decided to take my dexta to pieces, due to stuck piston rings. Ive never split a tractor before, but was wondering if i could take the sump off without removing the engine completely to access the crank?
Re: A couple questions
hi just done mine dropped axle off then head n sump off no problems at all
Ideal, thanks for that my friend. I was just worried that it may stress the block too much, but will give it a go!
It won't hurt the block. Its part of the tractor frame. You may have to pull the engine, if you need to have new liners installed. Although I have put finished liners in Perkins engines using freon or dry ice, to shrink them, and a liner puller in reverse. I don't remember if you can get finished liners for Dextas or not.
Ive measured the liners, and they are hardly worn, so im just going to replace the rings and bearings for now and see how it runs
hi nick been following you thread , it might be penny wise pound foolish, when you are in
so far , its alot of work if it still isn right to stat to strip it all again , might be better to
give the old girl a set of linners, then you know you have it right, hope it goes right for you
what ever , good luk Gerry
i have my engine all stripped down in the same way. i am going to replace bearings and rings. i will check the pump out though.
Ive coupled the injectors to the pipes out of the head and it seems to squirt well out of all three. Im waiting on a local tyre company to come and replace the tyres before i move it into my proper workshop - hopefully next week!
The other thing i was going to ask, ive got to take the fuel tank off to clean it out. To do that ive got to take the steering wheel off, is the big nut in the middle normal or reverse thread?
dexta steering wheel nut is normal screw thread, clockwise to tighten,
i had the same worry
when doing mine
Gerry
when doing mine
Gerry
