what paint //
Posted: Thu Jul 21, 2011 12:02 pm
by davysdexta
hi guys i got mi dexta all cleaned down right to bare metal n hand painted with red led (oxide)
am goin to rub it down an under coat her then finish her off with top coat /
after wire brushing i cleaned her with synthetic thinners before red lead ??
now the problem i got is one says one thing an another says somethin else
so would appreciate some help please ??witch under coat with what thinners an what top coat an thinners ???
or two pack an what thinners ??/really want HELP as i know some of u out thers have painted your dexta,s
an they look great on photoes all replys welcome
thanks davy
Re: what paint //
Posted: Thu Jul 21, 2011 12:43 pm
I have used Tractol on mine, easily available and easy to apply. Old Twenty has a good type of paint so I have been informed but I have not tried it.
Use the thinners for the paint. Some people mix clear varnish with the final top coat.
Do not like Two Pack, gives the wrong finish for those who want an "original" looking tractor. There are also Health and Safety issues if you read the instructions on the tins, for hobby users.
Re: what paint //
Posted: Thu Jul 21, 2011 1:32 pm
by Bensdexta
If it's a standard Dexta - Empire Blue (New Performance Supers were different).
See http://www.fordsontractorpages.nl/phpbb ... int#p14068
This paint is available from New Holland and is said to be a good match to the original. It's single pack. Perhaps not the most durable of paints, eg compared with 2 pack, and takes ages (weeks) to fully cure and harden off. But it's easy to apply and unlike 2 pack, next to no health and safety issues. :wink:
Re: what paint //
Posted: Thu Jul 21, 2011 6:51 pm
by pjjms
2 pack dangers should not be under estimated. It contains isocyantes and should only be sprayed in a booth using breating gear with its own air supply. Automotive paint shops are following car manufacturers and going away from it now. Water based paints are becoming much more common, but I have been told they are not easy to use.
Re: what paint //
Posted: Thu Jul 21, 2011 7:49 pm
by Bensdexta
pjjms wrote:2 pack dangers should not be under estimated. It contains isocyantes and should only be sprayed in a booth using breating gear with its own air supply. Automotive paint shops are following car manufacturers and going away from it now. Water based paints are becoming much more common, but I have been told they are not easy to use.
Is it possible to get water-based paint for our tractors? :?:
Re: what paint //
Posted: Thu Jul 21, 2011 8:05 pm
by YorkshireDextaMan
Davy, Don't know where you are up there in Northumberland, but you could go along to one of the Lloyds New Holland dealerships and get a couple of tins of New Holland (Empire Blue) Tractor paint, and a tin of Grey primer. It won't be the cheapest you can buy, but it will be the best, and there are quite a few Lloyds up there. jim
Re: what paint //
Posted: Fri Jul 22, 2011 3:24 am
by pjjms
I don't know the answer about water based paint for our tractors. I have never used it myself. From what I have been told it needs a top coat of convetional clear to get a shine. I just use enamel on my tractors, and theres some quality enamels out there now that give good results out of the gun. Mind you reading the can on that would scare you as well. The last can of orange I sprayed had something like 60% dry weight of lead! I though that stuff was banned in about everything.
I think it is important to use a good filter mask when using any spray paint, and some goggles. The eyes can absorp a lot of toxins as well.
Re: what paint //
Posted: Fri Jul 22, 2011 7:21 pm
by davysdexta
thanks guy,s
things are about as clear as mud ,there seems to be a canny variation of ideas
out there amongs different gentlemen .to favourin different paints ?????
think i,ll try the enamal one ,,try it on the wheels first if it goes wrong wont take
to much rubbin down again (ihope) thanks again for suggestions will let u know
how i get on,, before to long i hope
davy
Re: what paint //
Posted: Thu Aug 11, 2011 2:55 pm
by Wee59dexta
Im using a red oxide primer followed by grey and then a Sparex empire blue enamel paint sprayed from the gun. So far getting great results.
Re: what paint //
Posted: Thu Aug 11, 2011 5:18 pm
by davysdexta
hi tyrone
yes i used red oxide when cleaning down to bare metal but put it on with brush
now have it rubbed down ready for grey primer have given wheels a couple coats o
primer an re/ rubbed down ready for another couple /make sure its ok for top coat
empire enamel blue just as u say ////but at the moment work is gettin in the way
anthe blasted weather is,nt helpin either
davy
Re: what paint //
Posted: Thu Aug 18, 2011 11:25 am
by Wee59dexta
Here is a picture of my front cowl, I sprayed yesterday. This is the colour of Sparex Empire Blue enamel paint.
Does this look ok? It's a little bit darker in reality than in the picture.
Here is a link, because I cannot insert images for some reason!! :curse:
http://www.flickr.com/photos/skidancer/ ... otostream/
Re: what paint //
Posted: Thu Aug 18, 2011 12:07 pm
by tom lad
hi m8
i use photo bucket , easy lol wen u figure it out ! :oops:
bottom tab next to the image says IMG code , copy and paste that to ure thread job done ! not figured out image sizes tho :?
tom
nose cone looks really good , well done .
Re: what paint //
Posted: Thu Aug 18, 2011 1:03 pm
by Bensdexta
tom lad wrote:hi m8
Just click on pic, menu will appear, then select edit, resize to 640x480, replace original :wink:
Re: what paint //
Posted: Thu Aug 18, 2011 1:41 pm
by tom lad
cheers ben
Re: what paint //
Posted: Thu Aug 18, 2011 2:32 pm
by Wee59dexta
Cheers Tom lad and Ben. Think i've sussed out the old pics situ.
Noce Cone - After some hard graft by Skidancer1, on Flickr
