help needed
gamekeeper
help needed
Post by gamekeeper »
i'am new to the forum having recently aquired a super dexta, it looked a good place to come for advice and help. i'am not a mechanic and can only really bolt things on. i live in the newmarket suffolk area and wondered if there is any one living locally that would be willing to do a few jobs on my tractor .thankyou
Re: help needed
Can you give us an idea on what jobs need to be done? It may be that we can guide you through them. There are a number of board members fairly close to you that may be able to help. A few details will go a long way.
gamekeeper
Re: help needed
Thanks for your reply. There are quiet a few jobs but the ones I would like to addres first are hydraulic oil leak from pto shaft, hydraulic leak from the area under the seat , neither major but annoying also bush on clutch pedal I no I should be able to do it but I can't get the cotter pin out. Also the tacho cable which I have renewed dosen't 8) work it seems that where it goes in the engine it has worn . Just haven't really got time to do the jobs at the moment if I could ,but Willing to pay and able to transport tractor if that would help!
gamekeeper
Re: help needed
think i have found someone locally to help, thanks brian
Re: help needed
And I had just loaded all my tools in the car! Ah Well......... :D
They sound reasonably simple jobs so hope all goes well.
