i'm still trying to set my s dexta hydaulics .....
last time it was all together - ploughing - the lift in draft was becoming slower and slower , snap into position and it works perfectly (i didnt try it but i bet if i pushed the draft selector lever back it would speeded up .
i changed the cam follower pin a few years ago , still have prob .
i used to have a oil leak ( suspect unloading valve cap, bin machined out -new cap -nice and tight , but untested lol ) thanx for advice/ knoledge
if the pin wears then does the cam wear ? my pin was only about 1/3 , 1/2 through seen loads of photos of worse ones on here lol
lever in draft, my cam never touchs the pin , even arms fully down , so y does it matter were the lift is to make the settings ??? closest is about 5 mm , my pin is 7 mm from memory
if it goes back together im sure it will lift but slowly .. the control valve does not get pushed in fully , which i am presuming it should do to get full oil ..... snap into position i can easly push valve in all the way .
it seems i need another 4-6 mm on my turnbuckle ,i dearnt go less than 2 , 2 1/2 turns of thread in the adjuster ....
my lift arms are tight sezed on the spines , as they all are i think , so to be honest i dont really want to fully strip the cross shaft , un less i was sure it would help , can we by new cams ?
regard confused tom
so to add photos i need to join photo bucket or symular ? WOO HOO i added a picture
link to my photos ( i think
is my linkage correctly assembeled ?
