Is it possible to remove the check valve seat with out the special tool recommended in the w/s manual. The hyd. top that I have intentions of using has been exposed to the weather and I have noticed a little bit of rust on the check valve seat, which I was wondering if I could remove with some brasso?
It is possible to do it with a bolt and sleeve but if you break it you are in serious trouble. The seat is a very tight fit. If it is just a bit of rust on the seat a polish would do it but nothing more abrasive than "Brasso" or jewellers polish.
Thanks Brian
The rust is ever so slight, I could leave it and see what happens after I have reassembled it. How would one test to see if it works properly. I should probably really ask what is the function of the valve?
I did eventually get the front portion of the valve out after appling plenty of tool in a can and patience. That part was fairly clean.
