Hi Boys!
Thanks a lot, found it. I searched somewhere in the enigine, but now I found it...
Now I have an other problem. I bought my temp gauge at Agriline in the UK. It came with a thread:
and an adapter for a bigger thread:
which looks like this in the end:
But now my Problem. There was a sensor screwed in which looks like this:
The new thread (original) is to small. The adapter is to big...
What can I do now? I don't want to make a bigger hole in the engine... Tried also to buy a new adapter but no shops in my area offer one...
How does the gauge works? Is the temperature transfered to the gauge only by the small wire inside? Will it work if I cut the new sensor and fix it to the old one? Or will the new gauge breake after this?
Thanks George
