I have also seen some sparks comming from the starter solenoid when I start the engine.
If I had putt the battery the wrong way, without truning the polarity of the system, would everything work?
It has charing light, oil light, light inside the tachometer, charing (low charing, but it charges), the front lights and everything else works.
Could I then have put the battery back the wrong way? At what volt should it charge?
Thanks a lot
