Put another way, with the drop arms at a fixed position, there is about 40degs of rotation in the steering wheel.
Is this 'par' for a Dexta, or should I consider refurbing the bottom of the steering box. The nut and the top has been changed and shimmed up by someone who knows Dextas. I can't feel any significant lateral play in the drop arms, only fore & aft movement at the ends of the arms, so does that mean the bushes are OK?
TIA
