Clutch Pressure Plate Bolts
russelm
Post by russelm »
Does anybody know where I can get the special clutch pressure plate bolts from?
Or am I ok to use standard UNC bolts without the shoulder (I have 3 of the 6 original shouldered bolts)
Re: Clutch Pressure Plate Bolts
Post by Bensdexta »
russelm wrote:Does anybody know where I can get the special clutch pressure plate bolts from? Or am I ok to use standard UNC bolts without the shoulder (I have 3 of the 6 original shouldered bolts)
Try Malcolm Hipperson, I got a 2nd hand one from him. :wink:
blue32
Post by blue32 »
Yes, I experied also to buy the last one from a companie here in Norway, but after, one of my Dexta,s with double clutch...who it is double up with bolts, I also drilled the hole,s to overzise, and cutted a screewdrivershaft into new bolt,s (this fit the new hole) -I,d welded the outsaid of them, but mybee several method for ceeping them there?..is to try. It.s a major problem that this small bolts and hole,s got some gap. Good luck with it.
mikkel
Post by Bensdexta »
russelm wrote:Or am I ok to use standard UNC bolts without the shoulder (I have 3 of the 6 original shouldered bolts)
When I removed my old clutch, I found one ordinary bolt with no shoulder. Tractor had been operating like this for at least 15 years, so I can only assume that shouldered bolts are not essential
