forson dexta remote
montanakid92
forson dexta remote
Post by montanakid92 »
hey i just got a fordson dexta with the remote (i don't know if that's what you call it) underneath the seat hooked up the post pounder went out to pound some post and nothing. The line from the remote seems to get a little tight when I turn it on but not as much as id like to see. The three point works fine. maybe it's the valve on the post driver, going to pull that apart tomorrow and check it out. I appreciate any input you may have.
Thanks in advance
Lesfen
Re: forson dexta remote
Post by Lesfen »
And welcome to the board.
Located in Montana?
Were you able to get the post pounder working? Sounds like a 3 point hitch pounder?
How is your system hooked up? Single line out of the remote valve? With the return back into the filler plug behind the seat?
Or do you have the 2 way valve with a lever under the seat?
Cheers,
Les
