russelm wrote:Mine are fitted so cant guess the length but I recall that they only protruded by 15-20mm or so (guess you could measure them based on that)
They are two different lengths though as the thickness of the casting where they bolt through is different.
Mine did not have a spacer fitted.
Many thanks.
Armed with that info, I think I've found my bolts. Mine are both the same length as I have the later AC fuel filter bowl - just under 1" long inc the shoulder. Don't believe I had a spacer either.
