Cracked engine block
Posted: Sun Sep 25, 2011 10:01 am
by Martin46585
Hi guys, I am looking for advise on whether or not a crack in the block it's on the back of the engine between the battery and the heads ,just between the frost plugs is as serious a problem as it looks, as this is a replacement engine for one that is cracked also, though it is in the more usual place behind the filter. ...many thanks
Re: Cracked engine block
Posted: Sun Sep 25, 2011 10:13 am
by Bensdexta
Some photos would help.
Have a search on here, there are several threads on the subject. :wink:
Posted: Mon Oct 03, 2011 8:28 am
by russelm
Mine had this.
I drilled both ends of the crack and and opened the crack out before cleaning well and then using a liquid metal.
I ahve since presure tested the system and no lekas but only time will tell.
That area of the block is not structual and to be honest, I would have welded it had I been able to find my high carbon rods!
