Nothing here is ever easy, firstly one of the wheels on the pressure washer fell off, so had to fix that, then found the hose pipe had a hole in it, so i fixed that. Then i saw that the end of the hosepipe had been chewed by a cow, so i fixed that.
THEN found the pressure washer had no diesel in its tank, THEN found that the big diesel tank had run out too, so i had to syphon some out of one of the tractors.
Anyway, ive washed it off and it came up quite nicely, then decided to go for a drive on it, i.e, start it in gear and see if would free on its own (i dont know if its worn or just rusted to the flywheel). It didnt free off, but should i of been trying to stall it with the brakes on or something?
Also if i have to split it, i understand that its a pain to get back together, any advice?
