Could anyone tell me what the maximum weight the 3 point hitch will take on a Dexta, I'm looking at buying a box or bucket for moving soil/gravel/hardcore around.
Maximum Lift Load
YorkshireDextaMan
Re: Maximum Lift Load
You can usually tell when maximum weight of the Hydraulics has been reached when the front wheels lift off the ground,
jeveriss
- Contact:
I could always fit some casters to the bottom of the box.
I think it should lift 1/2 ton on the 3PL without complaining. A 5ft wide box is enough for a Dexta.jeveriss wrote:Hi,
Could anyone tell me what the maximum weight the 3 point hitch will take on a Dexta, I'm looking at buying a box or bucket for moving soil/gravel/hardcore around.Cheers
dexta roadless
The information I found is 1850 lbs(840 kgs). I think that is measured 60 cm behind the liftarms.
6o Dexta Roadless
62 Dexta
63 Super Dexta
75 Shilter UT
62 Aebi
62 Dexta
63 Super Dexta
75 Shilter UT
62 Aebi
That's interesting. Where did you find that?dexta roadless wrote:The information I found is 1850 lbs(840 kgs). I think that is measured 60 cm behind the liftarms.
Yes a good point about the distance of the load behind the rear axle. The arms will lift a greater load the nearer the load is to the rear axle.
dexta roadless
I just took a search on the google and found it here.
http://vintagetractorengineer.com/2009/ ... xter-data/
6o Dexta Roadless
62 Dexta
63 Super Dexta
75 Shilter UT
62 Aebi
62 Dexta
63 Super Dexta
75 Shilter UT
62 Aebi
