So i manage to get her up onto a trailer and home...and within an hour or two of tinkering i got it running...i couldn't believe it. The first drive revealed a horrific transmission whine,so my delight was short lived-into the farm workshop and we split her open to find water in the back-end and gearbox-thus resulting in the gearbox bearing races being heavily pitted. Managing to source all new bearings we fitted them and re-assembled everything,with new gaskets and oil-seals,then i took her out for a drive...no whine
Next on the list was to get the hydraulics working,which proved problematic with sticking valves etc,but the lift now works...but is 'sticky' as so to speak,so will require further investigation. Next was to give the engine some work to see what condition it was in,so i coupled her onto a 9 ton grain-drier on the farm and gave her a few days of steady running-thinking it would free off my suspected stuck piston rings...but no,engine was still breathing very heavily so i took it back off the drier and into the shed. Now im away to open up the engine and have a look,im suspecting broken piston rings but time will tell.
Anyway,thats me and my dexta so far
Ta , conar!
