Hi all-im after some advice from you knowlegable people out there . When i bought my dexta I had no V5 book and the tractor has no registration plates at-all. Is it possible to find out my reg. number from the serial numbers on my tractor?
Thanks in advance,conar.
Don't think it's possible to find your reg, assuming it has been registered, from just your tractor number (or engine no).
If you can find out what the reg might have been eg from uncovering paintwork, or from documentation, receipts etc, then you can check this against county records, see here: http://www.fordsontractorpages.nl/phpbb ... ion#p23486
good luck
