Replacing Thermostat
Posted: Thu Dec 01, 2011 10:38 am
Howdy -
So my project to replace the cooling hoses has now turned into a new radiator (which arrives tomorrow) and while I was removing hoses, I thought I might as well check the thermostat.
I appear to have the old water outlet from the head with the 7.3cm spaced screws. But what I believe is the thermostat looks nothing like the replacement parts I've seen online. It also appears to be firmly stuck - aside from undoing the two bolts and removing the hose adapter, is there any trick to removing the thermostat - or do I just need a little more force to pull it out?
Here's some photos I took:
Regards,
Mark.
Regards,
Mark.
