hydraulics
hydraulics
when i lower the 3 point linkage on my super dexta, nothing happens at first then it goes down all of a sudden.Any answers? true blue Brian Cox
Re: hydraulics
Sticking control or unload valve.
Re: hydraulics
thanks brian, what do I do to rectify?
Re: hydraulics
The top has to come off and the relevant valves cleaned and polished with either Brasso or jewlers polish. Not a bad job if you take your time. There are pictures here:
http://www.fordsontractorpages.nl/wiki/ ... tting.html
You can also check the Position Control pin and replace that if necessary at the same time.
Re: hydraulics
hi brian, can't seem to acess photos.
Re: hydraulics
Are you using "fordsontractorpages" and "dotty" as your codes? The link goes straight there for me.
Re: hydraulics
hi Brian,
using fordson tractor pages but don't know what dotty is. I am being asked for user name and password, which I have tried without success.
Re: hydraulics
As Brian says the two words he's given are user & passwordBrian Cox wrote:hi Brian,
Re: hydraulics
thanks Brian, got it at last, I will give it a go.
Re: hydraulics
have to wait a bit,tractor is in a lean to and weather is rubbish.
